I have noticed that there are few users here that use DOTNET.
I am getting an ERROR during compiling of N_m3u8DL-RE,
but its at random times and on random machines.
Code:user@debian12:~/git/N_m3u8DL-RE$ dotnet publish src/N_m3u8DL-RE -r linux-x64 -c Release -o artifact Determining projects to restore... Restored /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj (in 311 ms). Restored /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/N_m3u8DL-RE.Common.csproj (in 308 ms). Restored /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj (in 308 ms). /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/Log/CustomAnsiConsole.cs(18,26): warning CS8765: Nullability of type of parameter 'value' doesn't match overridden member (possibly because of nullability attributes). [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/N_m3u8DL-RE.Common.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/Entity/MediaSegment.cs(22,23): warning CS8618: Non-nullable property 'Url' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/N_m3u8DL-RE.Common.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/Util/GlobalUtil.cs(77,72): warning CS8604: Possible null reference argument for parameter 'path1' in 'string Path.Combine(string path1, string path2)'. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/N_m3u8DL-RE.Common.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/Entity/Playlist.cs(13,23): warning CS8618: Non-nullable property 'Url' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/N_m3u8DL-RE.Common.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/Entity/StreamSpec.cs(54,23): warning CS8618: Non-nullable property 'Url' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/N_m3u8DL-RE.Common.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/Entity/StreamSpec.cs(59,23): warning CS8618: Non-nullable property 'OriginalUrl' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/N_m3u8DL-RE.Common.csproj] N_m3u8DL-RE.Common -> /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/bin/Release/net7.0/N_m3u8DL-RE.Common.dll /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MP4Parser.cs(12,26): warning CS8618: Non-nullable property 'Parser' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MP4Parser.cs(17,30): warning CS8618: Non-nullable property 'Reader' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MP4TtmlUtil.cs(10,23): warning CS8618: Non-nullable property 'Begin' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MP4TtmlUtil.cs(11,23): warning CS8618: Non-nullable property 'End' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MP4TtmlUtil.cs(12,23): warning CS8618: Non-nullable property 'Region' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/HLSExtractor.cs(29,17): warning CS8618: Non-nullable property 'ParserConfig' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Config/ParserConfig.cs(10,23): warning CS8618: Non-nullable property 'Url' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Config/ParserConfig.cs(12,23): warning CS8618: Non-nullable property 'OriginalUrl' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Config/ParserConfig.cs(14,23): warning CS8618: Non-nullable property 'BaseUrl' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/LiveTSExtractor.cs(19,45): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/LiveTSExtractor.cs(33,27): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/LiveTSExtractor.cs(38,27): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/StreamExtractor.cs(23,16): warning CS8618: Non-nullable field 'extractor' must contain a non-null value when exiting constructor. Consider declaring the field as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/StreamExtractor.cs(23,16): warning CS8618: Non-nullable field 'rawText' must contain a non-null value when exiting constructor. Consider declaring the field as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/StreamExtractor.cs(28,16): warning CS8618: Non-nullable field 'extractor' must contain a non-null value when exiting constructor. Consider declaring the field as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/StreamExtractor.cs(28,16): warning CS8618: Non-nullable field 'rawText' must contain a non-null value when exiting constructor. Consider declaring the field as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MP4Parser.cs(132,40): warning CS8600: Converting null literal or possible null value to non-nullable type. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MP4Parser.cs(133,55): warning CS8600: Converting null literal or possible null value to non-nullable type. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MSSMoovProcessor.cs(68,16): warning CS8618: Non-nullable field 'ProtecitonKID' must contain a non-null value when exiting constructor. Consider declaring the field as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MSSMoovProcessor.cs(68,16): warning CS8618: Non-nullable field 'ProtecitonKID_PR' must contain a non-null value when exiting constructor. Consider declaring the field as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Mp4/MP4TtmlUtil.cs(145,21): warning CS0219: The variable 'sawMDAT' is assigned but its value is never used [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/HLSExtractor.cs(86,46): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/MSSExtractor.cs(55,45): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/MSSExtractor.cs(320,28): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/HLSExtractor.cs(220,38): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/DASHExtractor2.cs(69,45): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/Extractor/DASHExtractor2.cs(582,28): warning CS1998: This async method lacks 'await' operators and will run synchronously. Consider using the 'await' operator to await non-blocking API calls, or 'await Task.Run(...)' to do CPU-bound work on a background thread. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/N_m3u8DL-RE.Parser.csproj] N_m3u8DL-RE.Parser -> /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Parser/bin/Release/net7.0/N_m3u8DL-RE.Parser.dll /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/CommandLine/MyOption.cs(247,27): warning CS8618: Non-nullable property 'MuxOptions' must contain a non-null value when exiting constructor. Consider declaring the property as nullable. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/DownloadManager/HTTPLiveRecordManager.cs(87,13): warning CS4014: Because this call is not awaited, execution of the current method continues before the call is completed. Consider applying the 'await' operator to the result of the call. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/DownloadManager/HTTPLiveRecordManager.cs(89,13): warning CS4014: Because this call is not awaited, execution of the current method continues before the call is completed. Consider applying the 'await' operator to the result of the call. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/Program.cs(81,13): warning CS4014: Because this call is not awaited, execution of the current method continues before the call is completed. Consider applying the 'await' operator to the result of the call. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/Program.cs(308,42): warning CS8602: Dereference of a possibly null reference. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] N_m3u8DL-RE -> /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/bin/Release/net8.0/linux-x64/N_m3u8DL-RE.dll /home/user/.nuget/packages/microsoft.net.illink.tasks/8.0.6/build/Microsoft.NET.ILLink.targets(210,5): warning : Property 'TrimmerDefaultAction' is deprecated in .NET 7 and higher and will be ignored. Use TrimMode instead. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] Generating native code /home/user/.nuget/packages/nil.js/2.5.1600/lib/net6.0/NiL.JS.dll : warning IL2104: Assembly 'NiL.JS' produced trim warnings. For more information see https://aka.ms/dotnet-illink/libraries [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] /home/user/.nuget/packages/nil.js/2.5.1600/lib/net6.0/NiL.JS.dll : warning IL3053: Assembly 'NiL.JS' produced AOT analysis warnings. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] /home/user/.nuget/packages/runtime.linux-x64.microsoft.dotnet.ilcompiler/8.0.6/framework/System.Linq.Expressions.dll : warning IL3053: Assembly 'System.Linq.Expressions' produced AOT analysis warnings. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] /home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE.Common/bin/Release/net7.0/N_m3u8DL-RE.Common.dll : warning IL3053: Assembly 'N_m3u8DL-RE.Common' produced AOT analysis warnings. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] /home/user/.nuget/packages/spectre.console/0.47.1-preview.0.11/lib/net7.0/Spectre.Console.dll : warning IL2104: Assembly 'Spectre.Console' produced trim warnings. For more information see https://aka.ms/dotnet-illink/libraries [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj] Killed /home/user/.nuget/packages/microsoft.dotnet.ilcompiler/8.0.6/build/Microsoft.NETCore.Native.targets(308,5): error MSB3073: The command ""/home/user/.nuget/packages/runtime.linux-x64.microsoft.dotnet.ilcompiler/8.0.6/tools/ilc" @"obj/Release/net8.0/linux-x64/native/N_m3u8DL-RE.ilc.rsp"" exited with code 137. [/home/user/git/N_m3u8DL-RE/src/N_m3u8DL-RE/N_m3u8DL-RE.csproj]
Here is what does work sometimes and sometimes does not for strange reason...
#Install .NET
Code:sudo apt install -y libicu-dev libcurl4-openssl-dev zlib1g-dev libkrb5-devCode:curl -kL https://packages.microsoft.com/config/debian/12/packages-microsoft-prod.deb -o ~/Downloads/packages-microsoft-prod.deb sudo dpkg -i ~/Downloads/packages-microsoft-prod.deb rm ~/Downloads/packages-microsoft-prod.deb sudo apt update; sudo apt install -y dotnet-sdk-8.0Code:cd ~/git git clone https://github.com/nilaoda/N_m3u8DL-RE.git cd N_m3u8DL-RE
#Compiling
The log of successful compile is here:Code:dotnet publish src/N_m3u8DL-RE -r linux-x64 -c Release -o artifact
https://forum.videohelp.com/attachments/79738-1717775229/N_m3u8DL-RE.log
I have also tried this:
And the log is here (17M in ZIP file):Code:dotnet publish src/N_m3u8DL-RE -r linux-x64 -c Release -o artifact -v:diag > N_m3u8DL-RE-publish-dump.log
https://forum.videohelp.com/attachments/80489-1720370101/N_m3u8DL-RE-publish-dump.zip
I have tried numerous times the following and again and again,
but without result:
Code:rm -r ~/.nuget/ rm -r ~/.dotnet/ rm -r ~/.local/share/NuGet/ rm -r ~/git/N_m3u8DL-RE/
Also tried my favorite "search" enginge, but did not find anything meaningful
to explain what this error is about ....
found this - [Linux] Compiling N_m3u8DL-RE with DOTNET
The N_m3u8DL-RE project is a .NET-based application, and to compile it on a Linux system, you’ll need to follow these steps:
Install .NET on Linux: You can install .NET on your Linux system using a package manager, a snap package, or manually. You can refer to the official .NET documentation for more information on how to install .NET on your Linux distribution.
Clone the N_m3u8DL-RE repository: Clone the N_m3u8DL-RE repository from GitHub using the command git clone https://github.com/nilaoda/N_m3u8DL-CLI.git.
Open the project in Visual Studio: Open the cloned repository in Visual Studio, and make sure you have the .NET Core SDK installed.
Build the project: Build the project by running the command dotnet build in the terminal.
Publish the project: To publish the project for Linux, you can use the following command: dotnet publish **path to your solution** --configuration Release --framework netcoreapp3.0 --output .**output path** --self-contained false --runtime linux-x64 --verbosity quiet.
Note that the --runtime option specifies the target runtime for the published application, which in this case is linux-x64. You can adjust this option to target a different runtime if needed.
By following these steps, you should be able to compile and publish the N_m3u8DL-RE project for Linux using DOTNET.
N_m3u8DL-RE on Mac
By phineferb98 in forum Video Streaming DownloadingReplies: 19Last Post: 17th Dec 2024, 13:15 -
Compiling N_m3u8DL-RE for jailbroken iPhone
By stupid.345 in forum Video Streaming DownloadingReplies: 2Last Post: 13th Apr 2024, 13:25 -
Help me, where did i go wrong using N_m3u8DL-RE
By Ganteng in forum Video Streaming DownloadingReplies: 13Last Post: 2nd Apr 2024, 14:53 -
Need help me getting the N_m3u8DL-RE
By mrsimple8x in forum Video Streaming DownloadingReplies: 2Last Post: 19th Dec 2023, 07:29 -
[LINUX] can ffmpeg (or any othe linux command) genere an ANIMATED waveform
By Jintor_Universe in forum ProgrammingReplies: 5Last Post: 28th Oct 2021, 19:29
